Can you create a fillet between two parallel circles in a sketch?
e.g as shown in the pic here.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 6,004 image
    Draw a 3 point arc and make it coincident and tangent both ends.
  • insiya_dhroliainsiya_dhrolia Member Posts: 3 EDU
    Thank you! I used three point arc but I used AutoCAD before and I was able to use fillet option instead of arc and wanted to check if that would work on Onshape too. Students found fillet option much easier.
    Insiya
    @insiya_dhrolia
    To do a fillet, Onshape needs the unfilleted edges to touch at a point, which these circles don't appear to.
