How can I wrap a sketch around a cylindrical surface that tapers to a smaller surface?
arthur_nichelson
Member Posts: 7 EDU
The part of the surface I'm attempting to wrap it around is cylindrical, but not perfectly vertical and slightly tapers. Is there still a way I can wrap it around the surface?
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
@MBartlett21 I actually think the method @alnis_smidchens offered in this thread (https://forum.onshape.com/discussion/14537/how-can-i-make-a-sketch-wrap-around-a-non-cylindrical-surface#latest) is the best
5
Try using "wrap". It's in the transform drop down menu. Remember to select "solid".
Maybe @konstantin_shiriazdanov would have a FeatureScript for that?
I missed that it was slanted...
