Can you create a fillet between two parallel circles in a sketch?
e.g as shown in the pic here.
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,414
    Draw a 3 point arc and make it coincident and tangent both ends.
    insiya_dhroliainsiya_dhrolia Member Posts: 3 EDU
    Thank you! I used three point arc but I used AutoCAD before and I was able to use fillet option instead of arc and wanted to check if that would work on Onshape too. Students found fillet option much easier.
    Insiya
    MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU
    @insiya_dhrolia
    To do a fillet, Onshape needs the unfilleted edges to touch at a point, which these circles don't appear to.
