background
walterwalter Member Posts: 41 EDU
my blackground turn black in chrome how to turn back to white
  • walterwalter Member Posts: 41 EDU
     hardware acceleration in the browser turned on ,java up to date
    works in firefox
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 227
    Can you post the results of https://cad.onshape.com/check ?
  • Matt_LoMatt_Lo Member, Moderator, Onshape Employees Posts: 15
    We have been seeing a graphics driver or browser update causing this recently. Could you reboot your machine, then make sure your graphics drivers are up-to-date and then try opening Onshape? Let me know if this does not resolve the problem in Chrome
  • bjørn_hovdebjørn_hovde Member Posts: 3
    I have just got the same issue: Black backgruond in part studios and assamblies. Java updated, HW acceleration is on, happens in Chrome and in Internet Explorer and Microsoft Edge. GL renderer: Google SwiftShader. Measured triangles: 1.7 mill, Measured lines: 1.2 mill. Windows 10 is updated, which includes graphics update. Onshape has worked without problems until recently.
    I just tried Firefox, and I am back working with Onshape!
    Solved: brynjar_andresen in the discussion "WORKSPACE BACKGROUND IS BLACK?" suggested enable the flag in Chrome: "Override software rendering list". That solved the problem for me to!! Thank you very much!
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 554
    For those that have had this issue, can you type this in Chrome and then past the results back here in this thread: chrome://gpu
    I'm looking to see if there are trends with the graphics cards involved. Ideally we don't want users to have to enable the override software rendering list if possible.
