Won't accept the correct answer to my Data Management Learning Curve last question LINKED DOCUMENTS
ENNELLDEE
Member Posts: 3 ✭
I only need to answer the last question, which I did, in the Data Management Learning Curve sections which is the Linked Documents question. I answered it correctly at which point it should have sent me to get my certificate, but it won't accept the correct answer. So I can't get my certificate.
How do I get my certificate?
NeilCooke
Moderator, Onshape Employees Posts: 5,933
Are you absolutely sure the answer you are giving is correct?Senior Director, Technical Services, EMEA5 -
KatieHuffman
Member, Onshape Employees, Developers Posts: 194
@ENNELLDEE
Its not the quiz preventing you from getting the certificate, it looks likes you only completed 89% of the Linked Document course- to mark is as complete you must finish 90%. Make sure you have green checkmarks and bubbles on all the pages in the course outline. You must stay on a page for 3 seconds to achieve this. You probably clicked through a couple pages a little too quick.5
thanks, ~B
