Plane tangent and normal to surface?
MichaelPascoe
Member Posts: 2,671 PRO
I'm trying to place a plane consistently on multiple types of faces to use in a transform. I can get a plane that is normal to the selected face, but I keep getting stuck.
The plane needs the following conditions:
My current attempts end up either not aligned with the chosen edge or facing away from the selected face.
- Origin: middle of selected curve/edge.
- Normal: same direction as curve/edge.
- X-axis: always facing toward the selected face not away from it.
var loopedEdges = qLoopEdges(definition.face);
var evalLoopedEdges = evaluateQuery(context, loopedEdges);
var normalPlane = evFaceTangentPlaneAtEdge(context, {
"edge" : evalLoopedEdges[0],
"face" : definition.face,
"parameter" : .5,
"usingFaceOrientation" : true
});My current attempts end up either not aligned with the chosen edge or facing away from the selected face.
NeilCooke
Moderator, Onshape Employees Posts: 5,920
Use evEdgeTangentLine, then evFaceTangentPlane, then construct the plane from those results.Senior Director, Technical Services, EMEA1 -
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
You can borrow this function:/**
* Returns normally oriented (by z axis) coord system in the closest point of reference surface.
export function evRefCoordSys(context is Context, line is Line, referenceFaces is Query) returns CoordSystem
var distanceResult = evDistance(context, {
"side0" : referenceFaces,
"side1" : line.origin
var faceNormal = evFaceTangentPlane(context, {
"face" : referenceFaces->qNthElement(distanceResult.sides[0].index),
"parameter" : distanceResult.sides[0].parameter
}).normal;
var dir = line.direction;
dir = normalize(dir - dot(dir, faceNormal) * faceNormal);
return coordSystem(line.origin, dir, faceNormal);
}The trick is to perform Orthogonalization procedure of one of the vectors extracted from edge tangent and face normal to make sure those vectors are suiting for coordinate system definition. This is what does this string:dir = normalize(dir - dot(dir, faceNormal) * faceNormal);
1
}).normal;
In order to make the plane with all of your specifications, you may want to first make a coordsystem, then call plane(coordsystem) on that coordsystem. I hope that helps!
This takes advantage of qNthElement to avoid having to evaluate the query first.
Thank you! @NeilCooke @konstantin_shiriazdanov @Alex_Kempen
