How can I create an image from my shape and write the dimensions on it not by drawings
shaked_baharavshaked_baharav Member Posts: 2
I would like to know how I could add a dimension to my shape, and also, how can I capture a picture from my shape as you can see in the pic below.
I am doing a shape for a tissue engineering lab via zoom and we had to do a template, I already did but I have no idea how to add the dimensions and the angles.
can someone help me, please!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,838
    It is not possible to add/display dimensions on the 3D model. If you share the document, they can take measurements. If you need to see the dimensions, you will need to create a drawing.
  • alnisalnis Member, Developers Posts: 452 EDU
    Also, if you need a high-resolution screenshot to share with people, you can use "Print..." from the top left 3-bar menu to get a big image with an alpha channel (so that you can use it with any background).
  • john_smith077john_smith077 Member Posts: 175 ✭✭✭
    This is brilliant... except that the my lines are way too fat when printed. Any suggestions?
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 552 ✭✭✭
    Maybe try select a different print size, this one is A0
