Configuration Table problem
GHamsz
Member Posts: 32 ✭
I’m a relative newbie, so consider that...
Any idea what’s going on here?
I’ve used a configuration table before without issue, but for some reason I can’t reference the variables in this table.
I also don’t get any hint as to what the problem is.
It looks like you're using a mobile version of Onshape (iPad?). I don't think that variables are available on mobile (yet!).
@steve_shubin (who is a master on mobile) is that true?
You can indeed make variables using mobile
I may have found the root cause of my problem. I didn’t realize that when you rename a configuration variable, that the underlying #name isn’t changed.
Can you see the issue with the original poster's question?
I’m guessing you guys both posted at the same time
Evidently @GHamsz has it working good
