Face filleting error
Member Posts: 4 EDU
edited November 2020 in Community Support
Hello everyone!
I was filleting an object and I couldn't do it the way I am used to in other softwares.
If I select a face as an entity to fillet, as shown in the two pictures below, I get an error.
It only works if I select edges.
Onshape help doesn't say anything about not using faces while filleting. I would like to understand why this happened.
Thank you for your attention.
Best regards,
Goncalo Torres
UPDATE -  the document can be access through this link:
