Need help on a project
Andrew_GamboaAndrew_Gamboa Member Posts: 2
I try to do this thing, but I just can not complete at all
    What about it is causing you trouble?
    Have you looked into the sketching courses in the learning center?
    edited November 2020
    I assume you are new to sketch and modeling.
    Start by breaking it down into simple objects and build up from there.
    I would start by drawing the two circles 4.25 apart. Make sure you add dimensions to those until the blue lines turn black. Then keep adding the other circles, dimension thoes until black.
    Then keep moving on into the rest until everything is finished.
