Is there a way to expand the dimension text box?
As seen in the image below, it becomes cumbersome to enter and edit long equations in the dialog box that opens when you click on a dimension. If you hover you can see the full length of the equation. Is there a setting to make that dialog box bigger? Seems like something that should already just be bigger.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,050 PRO
    Not yet.
    There are request out there for this feature. Until then you will need to write it out in notepad and paste it in..
  • AustinPackardAustinPackard Member Posts: 7 ✭✭
    Looking for this improvement as well.
