Edit stl file
in General
i have an stl file that i need to edit to make some holes bigger.
Can this be done in onshape somehow? im able to import it but not edit it in any way..
Detailed guide wanted on how to make it eligeable for editing
1
If you want to edit the STL, there are free options out there for doing that. Look into using Meshlab, Netfabb, or Blender.
You're right! We'll try to make the documentation on this more clear. CAD files such as parasolid (.x_t), STEP (.stp), IGES (.igs), SolidWorks (.sldprt) and other native geometry files will come into Onshape as editable geometry. Finalized mesh files such as STL and OBJ files will come in as meshes, and are not currently editable in the system.
If you would like to help us prioritize this functionality please vote on https://forum.onshape.com/discussion/comment/24147
For now here is a list of all the file types we can import: https://cad.onshape.com/help/Content/translation.htm
If you have questions about whether a specific type will come in as a mesh or a solid please don't hesitate to ask.
You can now boolean with meshes.
I wrote a custom featurescript that accepts meshes. The link is in the thread below
https://forum.onshape.com/discussion/comment/53501/#Comment_53501
Jon Hirschtick once said in a webinar that converting an STL to Solid is now possible. When inquiring, he was referring to your custom feature Boolean Plus.
I miss a solid manual. Can that be solved here via the forum.
My feature doesn't actually convert it to a solid. It just lets you do operations on the mesh that you couldn't before. The end result is still a mesh, though, and will be exported as one.
To convert it to a solid, you have to go through an external program life Rhino or something.
