macOS Big Sur Safari makes Onshape work awfully.
I'm not sure whose problem this is but Big Sur Public Beta 2 using Safari makes onshore horrible to use, where the view window is flashing in and out of zoom by ~1 mouse scroll while trying to hover over features. It also causes hovering to not highlight edges and vertices. Google Chrome work fine still so I will use that for now, but thought that given that a lot of users will be updating to Big Sur next month on its release, Onshape should know.
It's also horrible that bug reporting is pissed into the wind by posting it to a forum, there should be a dedicated place so I feel like I'm not wasting my time.
Have tried using the OS built-in bug reporting mechanism?
I have used it with very good results. Someone in OS immediately looks at and follow ups. Your reported "bug" get assigned a formal ticket # and when it is fixed in an update you are contacted to let you know the issue has been resolved.
I'm just giving a try for Onshape on MacBook Air with Mac OS BigSur (11.0.1) to see if I can replace my old laptop (linux + windows).
Safari V.14 was very promising with performance check (about 120 millions TPS) but is horrible in use (very laggy and bugs in section-view for example, etc...)
However it seems to work fine on Chrome with less performance check measurements (110 millions) even if graphics are less clean (little blurry).
Is there anyone who can try it with a Mac?
Is Safari not compatible with Onshape?
Thanks in advance and sorry for my bad English (French...)
Cédric
To fix the issue of blurriness in Chrome, go to https://cad.onshape.com/user/settings (My account > preferences), scroll down to Environment profile settings, select "Create profile," set Match pixel density to "Yes," and save. That will increase the Onshape viewport resolution to match your screen resolution, but it may cause slower performance. That's why it may look blurry when in Automatic mode (since it chooses to render at a lower resolution to decrease GPU load)
Big Sur Vers. 10.0.1 is officiel version and no more Beta.
Thanks a lot for your answer and possibilities of settings "pixel density", I will try it.
@Evan
Ok I will "report a bug" in Help menu.
Thanks
