Problems with creating a hole
Hi,
I have to recreate a corner part of a Rubik's cube. The black cube in the attachment is the part I'm supposed to use as a reference. I created two parts: the cube and the protruding shape, now the only thing I have to do is to create the hole shown in the images. I tried:
- using boolean subtraction
- creating offset planes, and extruding shapes sketched on them
- lofting
- using the split tool and removing the faces
- creating a composite curve and isolating it
The closest I got is when I used the split tool and deleted faces.
What tools can I use to do it?
- lofting
If that's the case, try this
https://cad.onshape.com/documents/afa9ee8da5c4a879ef5c88a7/w/dce364e929964aacb7c54492/e/869af15cca8e08aebed4c9ed
https://cad.onshape.com/documents/55883f6534b58df092226765/w/52acfcfa74f71fc947224aab/e/db69ce835d7c4af471de8610
- https://cad.onshape.com/documents/91c4a08ef45ac6097584a563/w/19606f57ef0e73960e981c57/e/25e1662ae2896ca9e9808ff5
I apologize if I am misunderstanding your intent.
