I cannot dimension the slot
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    I have followed the instructions to no avail.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,937 image
    Dimension tool is working fine - make sure you are a) editing the sketch and b) clicking the geometry then placing the dim
    Thanks for replying, but what do you mean by "editing the sketch". Aren't we always drawing and editing at the same time? Please explain a) and b) more clearly.
    If the sketch is active then there should be a sketch dialog box showing. Since you are pressing the dimension icon you must already be in an active sketch. Just remember with the dimension tool you click and let go of the mouse button, then move your cursor away and click again to place it.
