Order parts created by split?
marc_lepagemarc_lepage Member Posts: 2
I am splitting one part into two by a surface. It makes two parts as desired, Part 1 and Part 2. No problem so far.
However, I want to rename them Part B and Part A, because A is primary and B is secondary. Again, no problem.
But if I do that, I have Part B before Part A in my parts list, because Part 1 becomes Part B and Part 2 becomes Part A.
Instead, I want Part A to come before Part B in my parts list.
Is there any way I can control the order the parts are created by the split?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,807
    No there is not. The order of the parts list in a Part Studio does not matter. When you create an assembly, you can reorder them in the tree so that your BOM is ordered how you like it.
  • marc_lepagemarc_lepage Member Posts: 2
    Thanks. In the end I redid everything with another technique, and did not use split, so it's in the desired order now.
  • EvanReeseEvanReese Member, Mentor Posts: 2,281 ✭✭✭✭✭
    I would also like to be able to re-order parts in the parts list. I'll submit an IR for it.
