Sweep tool help
yuggniiksyuggniiks Member Posts: 25 EDU
edited November 2020 in Community Support
Hi,
I'm attempting to use sweep to cut a shape through a solid.  The shape I'm trying to sweep is on this vertical face and is a rectangle:
I'm not sure why the feature is "angled" at the midway point shown circled in red here:
What is the recommended way to fix this, as if I mirror the sweep feature it looks like this:
Thanks!
Link to drawing:
  • yuggniiksyuggniiks Member Posts: 25 EDU
    Thanks @tim_hess427 !  I tested out your 'quick fix' with the overlapping solution and it worked!
    I will attempt the other two methods, for practice.
    @tim_hess427
    I was able to model your first two solutions.
    I'm now trying to understand the last recommendation, create a sketch of path, then extrude cut from that sketch.  I'm not sure I follow this one.  Do you have a simple example?  Or perhaps a link to this?
    Thanks again for your suggestions, they were helpful!
    Oh I see, I wouldn't have thought of that.  Brilliant!
    Thanks again for taking the time to educate :smile:
    No problem! I'm always picking up new tips and methods from these forums. I'm happy to pay it forward!
