Section Properties
matthew_stacy
Member Posts: 489 PRO
in General
Has anyone written a feature script or found a free application that calculates section properties (area, second moment of area, etc.)? Even if I had to export a DXF file of the section profile, that would still be better than a poke in the eye with a sharp stick.
From what I gather Onshape does not currently offer this capability.
2
- I = bh^3/12
- I = (2mm) x (3mm)^3 / 12 = 4.5mm^4
How do I get Onshape to provide that result for this example or more complex profiles?Twitter: @onshapetricks & @babart1977
- Section feature made by @MichaelPascoe: https://cad.onshape.com/documents/bdffe7bf48f3b4155e85d073
- Export DXF
- Drag'n'drop to online DXF property calculator: https://acube.xyz/ (free account required)
Just need to be careful that the units match, but this seems like a "probably good enough" workaround.@alnis is my personal account. @alnis_ptc is my official PTC account.
