Share part or drawing with students?
james_mcshea
Member Posts: 3 EDU
Can I create a part or drawing and then share with students so they have their own copy to work with? Is there an export feature that allows students to then import a version that they can edit?
I want to give them practice properly dimensioning more complicated part drawings without them having to create the parts.
Thanks!
Thanks!
NeilCooke
Moderator, Onshape Employees Posts: 5,992
If you share a document with copy enabled they can copy the entire document.Senior Director, Technical Services, EMEA5
