How do I set up my GPU to run in Onshape?
Katie_BosilovichKatie_Bosilovich Member Posts: 2
edited October 2020 in Community Support
I think I've read the Graphics Performance Help page at least ten times and I'm very frustrated. I have a GeForce RTX 2070 graphics card, but whenever I run the compatibility check, it says Google Swiftshader is being user to render the graphics. I have done everything the help page has said, and it still won't work. If anyone can help me figure this out, I'd really appreciate it, because as it is now, it takes minutes for onshape to register any interaction I have with parts.
    edited October 2020
    Hi Katie! Do you have multiple graphics cards installed on your device? Assuming you are using Chrome on a Windows device, you can ensure Windows defaults to the better graphics card by navigating through your system settings to Graphics settings and ensuring your browser is set to High performance. From there you can also ensure WebGL and hardware accelerated are turned on:
    Go to chrome://settings
    1. Click the Show advanced settings link
    2. Scroll down to the System section and ensure the Use hardware acceleration when available checkbox is checked
    3. Relaunch Chrome for any changes to take effect
    Check Onshape at this point. If it's still not working, you can try to force WebGL hardware rendering via the following:
    1. Go to chrome://flags
    2. Enable the flag called Override software rendering list
    Onshape, Inc.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 578 image
    edited October 2020
    @Domenico_D Windows 10 has replaced the need to access the nVidia Control Panel for setting the GPU preference per application. The area is under Graphics Settings. It's a more generalized approach regardless of the graphics card vendor, nVidia, AMD, Intel, etc...
    You can see what mine looks like here:
    @Katie_Bosilovich is your question answered with Domenic's suggestion? Were you aware of the Windows 10 Graphics Settings area? Can you provide a screenshot of what that looks like for you?
    @Katie_Bosilovich , I just went through the similar issue. In my case changing the display setting in my browser (Firefox) fixed the problem (somewhere in the Firefox>options if I recall correctly). The default setting utilizes the integrated graphics hardware to conserve power. There is high-performance setting to override that to utilize your GeForce GPU.
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    @PeteYodis or @lougallo Please, could you create an Improvement request to add that information in the Graphics Performance Recommendations ?
    Un saludo,
