Patterned mate connectors show in part studio but not when inserted into an assembly?
glenn_ball
Member Posts: 4 EDU
I'm new so maybe I'm not tackling this in the right way. I'm in a part studio. I have a piece of metal extrusion with slots in it. I need to make it easier to mate T nuts in the slots so I decided to add my own mate connectors. I did this on one side of the square extrusion. I then used a circular pattern to add the mate connectors to the other 3 sides. It looks fine in the part studio. But when I insert the extrusion into an assembly only the original mate connectors show up. The patterned ones do not. What am I doing wrong?
part with mate connectors on all 4 sides = https://cad.onshape.com/documents/68eb52ae51d245b0d919f5fb/w/9a1780e208f2c1dadd68faf2/e/26a49bb4d5dffe1da51cd4b2
example assembly with a T nut mated to one of the extrusion slots = https://cad.onshape.com/documents/51c77b9e5c7cc1e79490ec83/w/529a60ff9b2127c3d417ec7d/e/1814cc5241e87d50fb4c0336
Note this is a configurable part. The length can be varied. Not sure if that makes a difference.
If this is not a good approach to make it easier to mate the T nuts please help me with another approach.
thanks
thanks
1
NeilCooke
Moderator, Onshape Employees Posts: 5,971
Huh, didn't even know you could pattern mate connectors as "parts"
- it will be because the patterned mate connectors are not owned by the part. Set it to "feature" and use "apply per instance" to make sure they are owned by the part.
Senior Director, Technical Services, EMEA2
