Sketch Constraints often Breaking
Cyberphil
Member Posts: 8 EDU
I've found, more and more with rather complicated sketches, that often when dimensions or sketches are deleted in a sketch, somehow the sketch becomes unsolvable.
Example: I have a fully defined sketch (all lines black) that I wish to edit. I delete one constraint in order to make a change I want and all the sudden the sketch turns completely red and says it's unsolvable.
A document where this is happening often with some rather complicated sketches:
https://cad.onshape.com/documents/9a55bd90131e1850420c6aab/w/144b6c1875f0d3e4c4572010/e/5b0f638f59c64f0fa4952573
This seems extremely odd to me because deleting constraints should allow more solutions to the sketch, not less. Any insight as to why this is happening?
