Create new Part, In Context
If I end up creating a new part, when I'm editing some part in context, is there any way to insert it also? ..or do I have to create mate connectors and import the part in the assembly the normal route?
If the part is relative to the in-context part, then you should be able to simply insert it and use "group" mate with the other in-context part.
This is something you select when inserting?
Click that, then start selecting parts you want to mate together.
Just don't select assemblies.
The way I understand this group button is after I've inserted something in the assembly, using it on a few parts, they can move together, but it doesn't help me with the initial positioning of the part?
There is a "Composite Part" in Part Studio, but there is no way to replace the part with a composite part in the assembly.
Another option is a boolean union, but I'd like to keep my parts separate.
The answer was you need to insert and mate it as you would normally.
In-context just gives you a reference model to build off of
