Extrude Fill
famadorian
Member Posts: 390 ✭✭✭
If I select the fill in 3d, then extrude, then it works to extrude the fill
, but if I first select extrude, then select the fill from the features list, then it doesn't work. Why?;)
NeilCooke
Moderator, Onshape Employees Posts: 5,933
The difference is that a sketch is guaranteed to be planar.Senior Director, Technical Services, EMEA1
