sort an array by another array?
EvanReeseEvanReese Member, Mentor Posts: 2,530 PRO
I have an array of faces that are in a seemingly random order in the array (by index), but they are arranged linearly enough that I could measure them from a certain point and get a sortable list of values. How do I use the array of distances to re-order the array of faces?
Maybe this question is too specific and there's actually a better approach altogether. If so I'd love to hear it.
  • MBartlett21MBartlett21 Member, OS Professional, Developers Posts: 2,060 ✭✭✭✭✭
    @Evan_Reese
    Did you know that the FeatureScript maps allow the key to be anything? [1]
    Because of this, you can have a map of distances, indexed by the face Query. This makes sorting very simple, just using Onshape's sort function:<pre>sort(arrayOfQueries, function(a, b) { return distances[a] - distances[b] }) </pre>
    [1]: Values and Types
    @Evan_Reese
    Here is an example:
    // This map gets filled out with the keys being `Query`s and the values being `ValueWithUnits`s.
    var queryToDistance is map = {};
    var queryArray is array = ...;
    for query in queryArray {
      queryToDistance[query] = evDistance(context, ...);
    queryArray = sort(queryArray, function(a, b) { return queryToDistance[a] - queryToDistance[b] });
    @Evan_Reese
  • EvanReeseEvanReese Member, Mentor Posts: 2,530 PRO
    Thanks @MBartlett21 I'm not sure whether you meant make the face query the key or the value. I got it working by making it the value, with the distance as key, but I have a feeling I took the long way. If you have time I'd appreciate a simple example showing what's in each variable above.
    @Evan_Reese
    Here is an example:
