Threads in Drawings
Member Posts: 42 ✭✭
Hello,
Is it possible to show threads in drawings with a 3/4 circle in top view,
or with correctly arranged lines in sectional view?
Thank's for your help.
Frank
  • Member, Developers Posts: 3,947 PRO
    Onshape only supports cosmetic threads with holes created by the hole feature.
    External threads you will need to create a cosmetic thread yourself or cut a thread into the part.
  • Member Posts: 42 ✭✭
    Thank you John for your feedback
    It would be good to follow the specifications of DIN ISO 6410-1 for thread representations.
    There should be a circle function, so that the 3/4 circle could be represented. A line function already exists.
  • Member Posts: 13 PRO
    Why though? This is such a major feature to be STILL missing from OnShape. Everyweek I find something that I would expect to have in a professional CAD software
    They have a working list of priorities.
    The best way to get something moved up the list of important features is to stay vocal about it, get more users to upvote and be vocal themselves, create or up vote improvement requests, or reach out directly through the 'contact support' feature in Onshape.
    By being a pro member your votes have more weight also
  • Member Posts: 1 PRO
    This is sort of why I am not a pro user.  OnShape needs to improve to a pro level system first.
