Best surface measuring strategy?
What is a good method for measuring points on a surface within featurescript?
Is there a "create mesh" that I can apply to the surface first then measure those points?
There must be more efficient way than what I am imagining:
- Split the surface into a grid
- Measure the split points from a plane
EvanReese Member, Mentor Posts: 2,516 ✭✭✭✭✭
@MichaelPascoe take a look at the Attractor Pattern or Surface Pattern feature to see how to make a point grid on the surface, then iterate through them in a for loop to measure each one to your reference plane. Does that sound like it would do what you want?1
If he could put those on the surface of what you’re showing, I wonder if he would be able to select one of those UV lines with the measure tool, in order to get a distance
This will work perfectly for what I'm trying to do.
