Best surface measuring strategy?
MichaelPascoeMichaelPascoe Member Posts: 2,688 PRO
What is a good method for measuring points on a surface within featurescript?
Is there a "create mesh" that I can apply to the surface first then measure those points?
There must be more efficient way than what I am imagining:
- Split the surface into a grid
- Measure the split points from a plane
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    @MichaelPascoe take a look at the Attractor Pattern or Surface Pattern feature to see how to make a point grid on the surface, then iterate through them in a for loop to measure each one to your reference plane. Does that sound like it would do what you want?
