Mouse Highlighting Boundaries of Objects
famadorian
Member Posts: 390 ✭✭✭
When you move the mouse around in Onshape, it highlights the boundaries of objects.
For purposes of making a video to demonstrate an assembly, is it possible to toggle this highlighting, so that it doesn't do that?;)
However, be warned that it's not instantly perfectly set up with visuals like these just from the CAD import. Setting this sort of jet engine scene probably would take about 10-15 minutes from import to rendering.
Blender file: https://1drv.ms/u/s!AjfbxG8x44KRhtpOcvyv_gHliZ204w?e=Pm6WAN
Think you could make a tutorial taking from Onshape to a render animation like this?
10-15 minutes until the animation is rendering and you're just waiting on the computer. Rendering takes longer on this laptop!
Although it was more to do with wanting perfectly modeled parts, not just an artistic eyeball of what could be accurate. Which is why I stuck to CAD instead
