How to make a simple tapered cylinder.
I need a cylinder that is say 40mm diameter on one end and 30mm diameter on the other end.
I can't quite figure out the right technique.
marcus_bernstein Member, User Group Leader Posts: 35 EDU
I'd start with a sketch of one diameter and include a "draft" in my extrude. You could also sketch the angled cylinder/partial cone from a side view and Revolve it pretty easily, or even chamfer a straight 40mm cylinder.Any chance Onshape is looking for interns?
Philadelphia User Group Leader0 -
NeilCooke Moderator, Onshape Employees Posts: 5,866
Revolve would be the most efficient way.Senior Director, Technical Services, EMEA0
