Copy a Part from one Parts Studio to another Part Studio
tracy_evanstracy_evans Member Posts: 15 PRO
While I can copy a Part, I can not paste it into a different Part Studio. There is no Paste menu for this.
Help would be appreciated.
  • MichaelPascoeMichaelPascoe Member Posts: 2,845 PRO
    @tracy_evans
    To get a part from another studio, you need to use the Derived tool. Derived brings a part from a different studio, to the current studio you are working in.
    RENDERCAD
    @tracy_evans
    RENDERCAD
  • tracy_evanstracy_evans Member Posts: 15 PRO
    Thanks Michael,
    Once they are derived into another studio, are they editable in the new studio with all the steps? Or are they still connected to the old studio for editing?
    edited December 2020
    To use the original steps, you will need to go back to the original studio and change them there.
    If the studio is in the same document, the derive will automatically update the part. However, if the derived part is from a different document, you will have to update the version of the derived document for the part to update in the new document. Versions can be created by the drop down menu in the top left portion of your screen.
    Versions:
    Right click the derive in the feature tree to update or go to the original studio:
    RENDERCAD
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,077 PRO
    If you want to duplicate your part with the tree also. Then you will need to duplicate the entire part studio, then delete any features you don't need (usually features for other parts if you have multiple parts in a studio)
    Otherwise derive and in-context are the way to push a part into another studio for further editing, like Michael showed
