Datum Plane created in Parts Studio does not show up in Assembly. Create a Datum Plane in Assembly?!
Hello! I wanted to create a Datum Plane as an assembly reference on a solids face. This way I wouldn't have to "flip" the model over and over to mate surfaces together. But a Datum Plane (Offset = 0) created in Parts Studio doesn't show up in an Assembly. (Merge Datum Plane to Part?) There is no where to create a Datum Plane in an Assembly. Again I must unlearn what I have learned and come to the Onshape side! Use the Mate Connector young @christopher_owens !
User can constrain the part at mate connector highlighted in circle. So, this probably saves the datum plane creation in the assembly in such case.
In other tools such as Creo, Inventor it needs angular plane at offset position. To create angular plane it again require additional datum axis or line curve. So this task is somewhat inconvenient comparing to mate connector creation
So, I feel that for above condition Onshape is definitely excellent.
