Trying to make a helical channel but can't select helix
gianmario_scotti
Member Posts: 22 EDU
I am trying to make a helical sweep by using a helix as the path. I successfully did this a couple of times in the past, but now, for some odd reason, I am unable to select the helix as the sweep path.
https://cad.onshape.com/documents/d066794cb26bfe70de278868/w/02fb9c9db37537357cde3a7e/e/afd31314c93460fa62ef3a05
MichaelPascoe
Member Posts: 2,689 PRO
At a glance, it looks like the sketch you are sweeping needs to be touching the start of the helix.
If the helix is right where you like it. Try creating a plane on the tip of that helix and place your sketch there. There should be an option in the plane feature called Curved Point, use that.
Also, the helix could be hidden in the part or surface. Press the "~" key to filter through the parts that you cursor is over. You can also select the helix from the drop down "Curves" list on the bottom left portion of your screen.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
Thank you very much.
The squiggly key above the left tab key. "~"
Not the "-" key.
