Extruding shapes that are slots
mario_darceuil
Member Posts: 113 ✭✭
Hello I've made a lot of slots in my design and I want to exude them, somehow I'm having issues with this. The slots appear to not be fully constrained areas. Please show me how I can extrude the slots straight through.
I use a lot of slots with what i do too. Here is a feature that will do most of what you need all in one place.
https://cad.onshape.com/documents/5afccd5ef566ebe0825bd897/v/8c836b92655af8b260d994b1/e/4657c97252294d908102f7be
If that is the type of slot you are taking about at least
That was the code for the featurescript. There is a partstudio in there you can view as a sample.
Here is a GIF showing how to add the slot feature to your toolbar, and a quick demo of how to use it, also how to make a slot normally.
In the GIF i just used an in-line mate connector, treat the feature just like you would the built in Hole feature
Actually I believe the slot as a feature is better performance than explicitly sketching each slot. So the caveat is all good.
I've been doing it that way in SolidWorks since hole wizard added slots. But this feature is actually much better than the SolidWorks one
