Unable to use named views in Onshape drawings
EtDusEtDus Member Posts: 4 PRO
edited January 2021 in Drawings
Good morning fellow OS users,
I am having trouble using named views (Specific orientation with a section view) in a drawing. I am well aware of how I am supposed to do it since I did it in the past with a specific orientation only.
After creating the said named view, I try to select the orientation in the insert menu in drawing and the named view just doesn't show up..
So my question is: Should I be able to import a named view (Specific orientation with a section view) in a drawing or that feature is not developped yet?
Best regards
  • francois_bouletfrancois_boulet Member Posts: 65 ✭✭✭
    Try to refresh page before selecting the named view
    La simplicité est la sophistication suprême.
    Léonard de Vinci
    Regen Drawing (ctrl+Q) will need to be done every time you update the model.
  • EtDusEtDus Member Posts: 4 PRO
    edited January 2021
    Thanks for the replies,
    Even if I refresh the drawing and the browser page, the named view doesn't show up.
    I created a named view with a specific orientation and it does show up.
    It makes me think it doesn't work because of the section view....
    Have you guys tried to make a named view with a section view and successfully inserted it in a drawing ?
    Can't wait to have answers to this problem...
    n.b I tried it with an assembly and a PS
    You're right,
    There is a problem with section view and named view.
    Maybe you should ask for an IR on this
    Léonard de Vinci
  • derek_wardderek_ward Member Posts: 70 EDU
    Did this ever get resolved? I have modeled a workshop and I want to put each wall in a drawing sheet, but I would need to be able to insert a section view of my assembly. Display States does not work and my named views that I have created don't show up as options. Does anyone know how to get around this?
  • eric_pestyeric_pesty Member Posts: 2,245 PRO
    @derek_ward
    You wouldn't normally insert a section view directly (i.e. a view of the 3D model already cut) in a drawing as you would be missing "context" so I believe the omission of named section views from drawings in intentional.
    You can however create a section view of an existing drawing view. In you case I would insert a top view of your workshop and then create sections showing what you want from there.
    Thank you @eric_pesty! I think that a section view will work.
