Editing Logic
EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
edited January 2021 in FeatureScript
I'm making my first foray into Editing Logic Functions, and I don't seem to be wrapping my head around it. I've been able to make one boolean control another boolean. I also was able to make one length value control another one, but if I manually changed the controlled length, it wouldn't update when I changed the controlling value anymore. Why is that? Lastly, I'm trying to control a boolean with a pair length values and some greater-than logic, and can't seem to get it working. The link is here. Can someone help me understand why this isn't working? this is the code below
export function editTest(context is Context, id is Id, oldDefinition is map, definition is map, isCreating is boolean) returns map
    if (definition.meLength1 > definition.myLength2)
        definition.yourBoolean = true;
        return definition;
    else
        definition.yourBoolean = false;
        return definition;
for some reason the code for > formats a $gt above, but it's > in the feature studio.
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    aaaand, in re-reading the code above I noticed a typo that caused it to fail. Onshape, can we please delete posts so as to not embarrass ourselves?  :D
