Can I make a copy of a OnShape Folder?
I have an OnShape Folder that contains other folders, documents, parts, assemblies and drawings called 2020 Robot.
I want to make a copy of the folder and all it's contents and call it 2021 Robot, then make 2020 Robot Read Only.
Is this possible?
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,055 PRO
    Yes and no, you will have to make the folders manually and copy each document one at a time aand move them.
    Or have some app written using the API I suppose
  • mike_hölschermike_hölscher Member Posts: 110 ✭✭✭✭
    It is also an option to Version or Release the 2020 Robot, freezing it.
    Ah right, I got caught up in the copy part of the question, i forgot it isn't necessary...
    If you don't want to release, you can also just create a version.. Versions are read only and if someone edits by accident then you can restore back to the version.
    Or create a branch anb delete the active workspace of the branch, that will make that bnanch read only basically
