Displaying Part Weight in a drawing
tim_wheeler
Member Posts: 19 PRO
in Drawings
I feel like I must be missing something, but how do I display the calculated weight (mass) in a drawing?
In my note drop-down, it does not appear as a usable property in a note.
Vote for this IR: https://forum.onshape.com/discussion/7920/implement-mass-properties-of-materials-into-insert-sheet-reference-dropdown-for-drawings
You need to set the density of the material manually, but it remembers the density, material name, and custom property IDs so it's pretty easy to use.
expanding on his set material feature, I've made it so i select the material through the feature as well, kind of like killing 2 birds with 1 stone.
Also allows for calculating and displaying different units per part. Some in grams, some in pounds etc.
I recommend copying the feature and modify the table to fit your material library.
