I'm trying to make a hole in a shape but it keeps saying merge scope for some reason.
Can you tell me how to fix it?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    Sounds like it doesn't know which part to put the hole into - for merge scope, select the part(s).
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,054 PRO
    To add an object to the merge scope, click down in the red area (where it says merge scope) and select what objects you want to merge with
