extrsion impossible
bernard_ciret
Member Posts: 4 ✭
why is impossible to extrude a cylinder in the corner of a box when the base cercle is tangent to the both side ?
pourquoi est il impossible d'extruder un cylindre dans l'angle d'une boite quand le cercle de base est tangent aux deux cotés ?
@bernard_ciret
If you really need the cylinder in that position, extrude it as a new part.
Or, move it slightly away from the edges so that the cylinder does not share an edge with the box.
CADSharp - We make custom features and integrated Onshape apps! cadsharp.com/featurescripts 💎
