Having bar slide within gap between two parts?
Hi all-- Engineering/robotics teacher new to OnShape here. I'm trying to have my students work on some linkages while we're remote, and I'm stuck trying to create a slider channel. I have a bar that I want students to be able to slide vertically within the gap between two existing pieces (creating a crank and slider linkage). I can create a slider or pin slot mate to have it slide with an existing piece, but not in negative space. Is there an easy way to define the gap between two pieces such that I could put a mate there?
Link to document:
https://cad.onshape.com/documents/c0a9265a0b1133f525814c09/w/687a0d6dad0cee6180dd6540/e/6f4be116e673d794f95a55f0
Thanks!
Link to document:
Thanks!
