Assembly
gabriel_w124gabriel_w124 Member Posts: 2
I was doing a project for school that consists of a Geneva Cam Assembly. When I put it together, it goes through the Geneva Cam. Does anybody know how to fix it? The assembly is available to edit. https://cad.onshape.com/documents/18e825534c3b12d1d058b917/w/4cbef6cfe7ecae5393658a23/e/66d1f8e4f4d7013613faec24
  • bertrand_maillard881bertrand_maillard881 Member Posts: 6 EDU
    Hello, it is impossible to open your document , problem with permission ....
    Bertrand MAILLARD
    Enseignant  LPO Jeanne d'Arc
    Responsable informatique
    Sainte Adresse - France
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    @gabriel_w124 - Geneva cams require intermittent contact which is not possible in Onshape. However, there are some crazy workarounds if you have the time and the inclination: https://forum.onshape.com/discussion/10484/rubiks-cube-mate-animation/p1
  • cfraytetcfraytet Member Posts: 3 EDU
    @NeilCooke : As of May 2020, you said 'intermittent contact' was not possible in Onshape. I'm currently teaching 9th graders Onshape on Chromebook and was hoping to do the Geneva Drive as well. Shall I expect that function to be available sometime during spring 2021? If not, I need to plan on a different project.
    Thanks!
    Carl
    @cfraytet - there are no plans to do this in the short term.
    @NeilCooke : As of May 2020, you said 'intermittent contact' was not possible in Onshape. I'm currently teaching 9th graders Onshape on Chromebook and was hoping to do the Geneva Drive as well. Shall I expect that function to be available sometime during spring 2024? If not, I need to plan on a different project.
    Thanks!
    Carl
    Thanks!
    Carl
    I think we can safely say you need to choose another project.
