Part Scaling in Onshape
Hi all,
I am trying to scale a finished part, does anyone know if Onshape does scaling?
Thanks,
Jeff
Thanks,
Jeff
This just saved me so much time. I actually needed to scale a sketch, but used this scale part function, then just created a sketch from the part.
Thanks!
Any point selection should work - that is the point that does not move in scaling. It is only important if you want to control end position of the part.
https://cad.onshape.com/documents/a9e269b89c55888131122ba3/w/441fc8bec72aef2b5be3ed5d/e/2c13dd92de1ec66a4a97229c
Thanks so much! My favorite team member was really helped out by this solution.
