Remove tool with curved end
Member Posts: 5
I am trying to remove something through the center of an object, and I want to make it so instead of the removing ending with a flat surface, it ends with a curve. I am fairly new to onshape so I am not quite sure on how to actually create the curve at the end of the removed part, without switching to a different plane.
