feature not replicating in linear pattern
tom_seibold
Member Posts: 20 ✭✭
I created a small part and would like to connect several such parts together with "sprues" for 3D printing. I extruded a 1mm-diameter feature which is clearly part of the merge scope of "part 1," but when I specify part 1 to be a linear pattern (with the intention of each sprue extending into the next one to make a single part out of all the replicants), the sprue does not appear on any of the repeats as part of the linear pattern. Suggestions welcome. https://cad.onshape.com/documents/e904677ce27c21270c7b3774/w/785fe5367450b548e390aaed/e/d0b013d475a8ac0f0af3c257
john_mcclary
Member, Developers Posts: 4,002 PRO
Your sprue 1 feature is after your pattern.
You will need to move your pattern down to capture the geometry.
This is a feature, the tree reads from top to bottom and each feature can only see what came before it.
So if you wanted to pattern these parts, and then later add sprues to some of them, you don't have to worry about messing up your pattern
2 -
wayne_sauder
Member, csevp Posts: 629 PRO
Sometimes I use a sketch and extrude remove.
https://cad.onshape.com/documents/23a48204df28ab096ff2301b/w/0934a705589631f0cca9204c/e/d77c5cc3e4247358a596d86b
1
I can always manually trim them off from the printed item as I will the between-part ones, but it would be nice to skip that step if possible. I have considered making the left-right sprue a separate part and repeating it two more times, then doing the same for the top-bottom sprues (no repeat), but I assume I'd then have to do a Boolean to join them all into one. I also experimented with the "up to..." extrude options, but those apparently don't work with pattern-repeat items that are below it in the list.
My problem with that is there are a lot of sketch entities that may break or need to be adjusted if the pattern quantity changes.
Whereas with the delete face no matter what the change is in the pattern, you can:
press spacebar (clear the selection)
view normal to the right face, window select the nubs on the left
view normal to the front face, windows select the nub on the right
so the recovery is simpler for future modifications.
