Default Offset Rotation for assembly mates
imants_smidchensimants_smidchens Member Posts: 69 EDU
edited February 2021 in Product Feedback
I greatly appreciate being able to reorient mate connections in assemblies without having to edit individual mate connectors, but have found that practically every time I need to reorient something like a fastened or slider, it needs to be rotated about the Z axis, rather than its local X or Y. Personally i would find it a timesave if the default rotation was around Z instead of X.
  • SR_integratorSR_integrator Member Posts: 39 PRO
    Indeed, I always want to rotate around the Z-axis.
    Please make Z-axis the default!
  • ethan_doak1ethan_doak1 Member Posts: 11 PRO
    Agreed!! This is how I feel as well.
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,016 image
    @imants_smidchens This will fall into the category to remember your last settings which we have on the plan.
