Why isn't it possible to pattern a spline?
terry_kuehne236terry_kuehne236 Member Posts: 13 ✭✭
I'm trying to remove drawer edges and I'm wanting to do a linear pattern in the sketch. Would this process be better done at the feature level?
  • terry_kuehne236terry_kuehne236 Member Posts: 13 ✭✭
    How do you pattern a feature when you can only pattern parts, it seems.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,987 image
    In the pattern feature, select feature pattern instead of part.
    Always.
