Removal of model lines for meshing purposes
Malcolm_Akner
Member Posts: 9 ✭✭
Hi all!
I've been using Onshape for a while now, and I'm meshing my geometry with Salome. It turns out that the model lines (image) forces Salome to attach mesh elements on those lines, and thereby adding more elements than necessary. I want to remove these lines in an efficient manner (there are 259 tubes, they have mode lines on 4 locations for each tube, on both inside and outside, so ~259*8 lines need to be removed). Is there any way of doing this in Onshape?
