Reuse a previous feature to make another Part, a "lost" tool in a Boolean-Merge for example?!
christopher_owens
Member Posts: 235 ✭✭
I did locate the Loft that created my "lost" tool part used in a Boolean-Merge. What if there was a "Use" or "Recreate" option in this menu??? Then I could make a new Part using Loft 1 without a lot of hassle!
It will appear in the feature list as "Transform"; in a complex model it might pay to give it a more specific name, like "Copy for Tool" or some such.
ON EDIT
For better clarity of purpose, rather than settle for the default "translate" option, pull down the menu to choose "Copy in Place"
It's not strictly necessary to think of everything you may need to do in future with the model, because you have "rollback" which is, essentially, Time Travel.
