Best way to determine if a query is "empty"?
brooke_spreenbrooke_spreen Member, Developers Posts: 115 ✭✭✭
I often find myself writing something like:
if ( size(evaluateQuery(context, my_query)) > 0 ) {}
Is there a better way? It seems like `qEmpty()` should be useful, but so far no dice....
PS - is it possible to make pretty code quotes in this forum? The option under `Paragraph`>`Code` seems to corrupt some characters...
Design Engineer | Anerdgy AG
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    A query does not contain anything, only when it’s evaluated. The result of an evaluation is an array so you can also do if(evaluateQuery(context, query) !=[])
  • brooke_spreenbrooke_spreen Member, Developers Posts: 115 ✭✭✭
    Makes sense, thank you! :)
    edited February 2021
    If it is a user selection you are testing you can also use verifyNonemptyQuery
    Very elegant!
